Hi, I've recently picked up a 2014 A7, I'm getting quite a bit of wind noise from the passenger window. I've investigated and the window doesn't quite go all the way up when you shut the door, probably about 2-3 mm short.
Does anyone know of a way I can sort this out?
Thank you in advance!
Hi do the global opening and closing a couple of times on the key fob and that should re educate it.
Cheers Steve, I'll give it a go in the morning!
