Firkindolloper Posted April 16, 2024 Posted April 16, 2024 Hi Guys, I have read that others have had a similar issue with their A4 TDI Avant S Tronic hesitating when pulling away from a junction or joining a roundabout etc. Has anyone ever had it fixed? I have this issue and it is currently with Audi Poole for them to look at it. I have had this Approved Used, 43k mileage car a month now and they know I will reject it if they don't fix it. I like the car and just want it fixed.
steviewevie Posted September 10, 2024 Posted September 10, 2024 I have a 35 TFSI and the only issue I have found is the slight delay in restarting after auto start/stop has shut the engine down. If I want a smart getaway, I either switch off the start/stop for part of the journey or blip the accelerator just before I want to pull away to wake up the engine.
Steve Q Posted September 11, 2024 Posted September 11, 2024 If it's over a month then you'll be unlikely to be able to reject it
Sheppard Posted October 15, 2024 Posted October 15, 2024 So I have a A4 14 plate which has the same problem is there anyone issues you have been told may be the problem???
Steve Q Posted October 15, 2024 Posted October 15, 2024 Have you had a diagnostic check to see if any fault codes flag up. When was the gearbox last serviced?
Sheppard Posted October 15, 2024 Posted October 15, 2024 Hi I’ve only had her since late may,I think It needs a service,I will get it booked for a service,what does a gearbox get when serviced??
