Mattgoody Posted April 21, 2024 Posted April 21, 2024 Hi all after some advice. I had the dreaded gearbox malfunction come up. Had the ECU in the gearbox all re done with new pins and ribbon. All was good till last week when. This happened in the video. Any advice would be appreciated PXL_20240419_133758680.mp4
Mattgoody Posted April 22, 2024 Author Posted April 22, 2024 21 hours ago, Steve Q said: When was the gearbox repair carried out? It was carried out around 2 months ago. Coming up with cam bus error. Is this to do with the fuse box etc under the front windscreen in the engine bay
Mattgoody Posted April 22, 2024 Author Posted April 22, 2024 Really not sure. Will keep you posted if I get it sorted 1
Mattgoody Posted July 13, 2024 Author Posted July 13, 2024 Had the fuse box under the driver's side of windscreen cleaned out as was full of water and been ok for 7 weeks. Today the dreaded message came back on and would only select even gears. Turned off and back on all ok again 🤦♂️
