Iby Dad Posted April 28, 2024 Posted April 28, 2024 Hi, I have just upgraded to 22’s and need a set a new tyres, please can you recommend some good quality tyres for these alloys? Thank you
Steve Q Posted April 28, 2024 Posted April 28, 2024 Can't recommend trees but I'd recommend a full wheel alignment and Speedo recalibration as it could be out more than normal.
GrimleyQ7 Posted June 25, 2024 Posted June 25, 2024 I run 22" wheels and have 285/35 tyres fitted which I sourced on Oponeo. Nice tread pattern and good grip to wear ratio. I can't remember the make/model and it's dark out now but I think they are Nexen Most online tyre suppliers have a budget, mid-range and stupidly expensive range. I went mid-range and they were less than £200 each. HTH. Chris
Magnet Posted June 25, 2024 Posted June 25, 2024 Hello Iby, I guess you have worked out/taken advice on the correct width and profile (very low) you will need to retain the correct rolling diameter of these large wheels - ? Kind regards, Gareth.
