Fixed its self
Go to solution Solved by Steve Q,
Posted (edited)
Gearbox in my A3 had been notchey  since purchase. Dawned on me today this is no longer the case. I may still carry out a gear oil change. Shouldn’t temp fate but I do like a free fix 🤔😁
Edited by enc
  • Solution
You're lucky. I'd still recommend a gearbox oil change to be on the safe side
  • Thanks 1
The pessimist within me does not believe mechanical faults fix themselves. I would investigate further before feeling lucky.
Posted (edited)
it was notchy with the need to sometimes try a couple of times to get first and third to select… and now it isn’t. What exactly can be investigated 🤔😂I’m not about to start pulling things apart when everything is working as it should 😉
Edited by enc
As you wish, but I'd be concerned that the gear change links or the clutch release lever are loose.
Just realised I posted this in the 8p forum. Can a moderator swap this to the 8v section please ?
thanks
