Zed Posted April 29, 2024 Posted April 29, 2024 Changed the window reg on my q7 (driver's side) but for some reason when winding the window back up, it stops and opens half way again. I have to wind it back up clicking on the button a few times rather than pulling the button up in just one go. I have tried re-learning the power windows and checked to see if there was anything that was in the way but nothing.
GrimleyQ7 Posted June 24, 2024 Posted June 24, 2024 Hi Zed I replaced my drivers door window reg too and it did exactly the same thing. I used a bit of silicon lube spray on the regulator tracks inside the door (yes, had to remove it, spray it and re-fit it) and that sorted it out. Hope that helps (if not already sorted in the 2 months). Cheers. Chris. 1
