Tommeh93 Posted April 30, 2024 Posted April 30, 2024 Recently bought an a4 avant, drives fine and no lights on dash. However start/stop doesn’t work and I’ve noticed when scanning it I get one code U010E lost communications with reductant control module, just wondering if this is normal with an adblue coded out?
David Angus Posted May 19, 2024 Posted May 19, 2024 I had a problem when I overfilled with adblue from a pump, and the full tank did not register as it had done the previous six times over 3 years. (2016 2.0 TDI). The mileage warning kept ticking down and I was worried the engine might get to the point where it would not restart. My local independent repairer recommended a soft ware fix. This eliminated the adblue messages and apparently I won't ever need to use adblue again. After the modification the stop/start engine function disappeared and I got 30% increase in engine performance. Engine shape warning light came on again after 500 miles, but car is running fine.
Hammie1982 Posted May 19, 2024 Posted May 19, 2024 I dont have it mapped out on an Audi, but I mapped it out on a Seat Alhambra about 12 months ago. Several times it didnt register a full tank fill up.... I took it to Seat each time and they done some sort of Software reset and it worked each time! Well this last time it didnt work, they scratched their heads a little bit and then their beards and their manhoods and then said it needed a full system replacement! They told me they would see what they could do as it was an ongoing problem and they might get the price reduced by 10 - 20% but it would likely still be in the region of €3500 I told them i would have it fixed else where and drove to a small garage where i know there is a little computer genius. He told me to give him 10 mins to have a look at it and see if it was going to take long, 5 mins later he informed me i owed him €200.00 and told me "you will never have this problem again" He was right... 25k later ive not had that problem again!
jdragon Posted May 28, 2024 Posted May 28, 2024 On 5/19/2024 at 9:47 PM, Hammie1982 said: I dont have it mapped out on an Audi, but I mapped it out on a Seat Alhambra about 12 months ago. Several times it didnt register a full tank fill up.... I took it to Seat each time and they done some sort of Software reset and it worked each time! Well this last time it didnt work, they scratched their heads a little bit and then their beards and their manhoods and then said it needed a full system replacement! They told me they would see what they could do as it was an ongoing problem and they might get the price reduced by 10 - 20% but it would likely still be in the region of €3500 I told them i would have it fixed else where and drove to a small garage where i know there is a little computer genius. He told me to give him 10 mins to have a look at it and see if it was going to take long, 5 mins later he informed me i owed him €200.00 and told me "you will never have this problem again" He was right... 25k later ive not had that problem again! So what did the computer genius do? 🤔 2
Hammie1982 Posted May 28, 2024 Posted May 28, 2024 2 hours ago, jdragon said: So what did the computer genius do? 🤔 deleted the Adblu system from the ECU essentially. Car doesnt know its there essentially!
