Wayne Blake Posted May 5, 2024 Posted May 5, 2024 Hi All I have A6 (C7) Avant with a constant on rear wiper. Just need confirmation re location of rear wiper relay, if anyone can help, thanks. Wayne
Stevey Y Posted May 5, 2024 Posted May 5, 2024 38 minutes ago, Wayne Blake said: Hi All I have A6 (C7) Avant with a constant on rear wiper. Just need confirmation re location of rear wiper relay, if anyone can help, thanks. Wayne Hi Wayne I don't think its the relay it is most likely the motor, because they are a cr@p design and fail frequently over the 190k I had the car I went through three rear motors all with different symptoms of failure, constant running, parking of wiper arm in multiple positions, no wiper at all, this is due to water ingress in to the control box PCB, never changed the relay ever, but if you use reverse logic if it works why is the relay at fault, most common symptoms of relay failure are, intermittent function or no function at all. Steve. 1
