Bengo345678 Posted May 7, 2024 Posted May 7, 2024 Hi, Is it possible to refit a pair of non xenons to a car previously fitted with xenons without modification? ie is the wiring the same? i know you need to modify when going the other way.
Steve Q Posted May 7, 2024 Posted May 7, 2024 You'll need it all coding and wiring will be different as xenon headlights have additional modules and ballast etc. Why do you want to fit halogen lights?
Bengo345678 Posted May 7, 2024 Author Posted May 7, 2024 mostly cost related. i've had a bump and can get halogen replacements a lot cheaper.
Stevey Y Posted May 7, 2024 Posted May 7, 2024 5 hours ago, Bengo345678 said: mostly cost related. i've had a bump and can get halogen replacements a lot cheaper. Hi halogen lights are cheaper until you get in to the coding and wiring changes, you might be better served buying second hand apart from that the majority of people want xenons because the light output is far superior, you may well spend a lot of money to fit halogen lamps only to be disappointed when you can't see as well. Steve.
