squeakyclean32 Posted May 10 Share Posted May 10 Hi,聽 as per the title would 2 adult gravel bikes fit inside an A4 Advant boot? I don't really want to have to keep fitting a bike rack to the car 馃檲馃槃 I currently own an S5 but the boot slopes down. Thanks 馃憤馃槂 聽 Quote Link to comment Share on other sites More sharing options...
rookiediver Posted May 10 Share Posted May 10 Hi, I have a 2021 A4 Allroad and often put 2 mountain bikes in my car. Both are medium frame adult bikes, but have to remove front wheels. 聽 Cheers 1 1 Quote Link to comment Share on other sites More sharing options...
squeakyclean32 Posted May 10 Author Share Posted May 10 2 hours ago, rookiediver said: Hi, I have a 2021 A4 Allroad and often put 2 mountain bikes in my car. Both are medium frame adult bikes, but have to remove front wheels. 聽 Cheers Thanks for your reply 馃憤聽 that's helpful馃憤馃憤馃槂 Quote Link to comment Share on other sites More sharing options...
rookiediver Posted May 10 Share Posted May 10 meant to mention that the Allroad has a sort of parcel shelf, but that simply unclicks both sides, but not a volume issue for me, and was the reason I bought the Allroad (nearly bought an A4 Avant) as once forgot I had bikes on a roof rack and went through a low barrier! 1 Quote Link to comment Share on other sites More sharing options...
squeakyclean32 Posted May 10 Author Share Posted May 10 6 hours ago, rookiediver said: meant to mention that the Allroad has a sort of parcel shelf, but that simply unclicks both sides, but not a volume issue for me, and was the reason I bought the Allroad (nearly bought an A4 Avant) as once forgot I had bikes on a roof rack and went through a low barrier! 馃憤...OMG.... not good at all but easily done. Quote Link to comment Share on other sites More sharing options...
Shazzc Posted May 30 Share Posted May 30 I can easily fit 52 and 56cm road bikes without removing wheels in the boot with the seats laid down.聽 It sometimes takes a bit of jiggling to free handlebars from wheels but I lay them top to tail - handlebars facing front on the bottom bike. 1 Quote Link to comment Share on other sites More sharing options...
squeakyclean32 Posted May 30 Author Share Posted May 30 39 minutes ago, Shazzc said: I can easily fit 52 and 56cm road bikes without removing wheels in the boot with the seats laid down.聽 It sometimes takes a bit of jiggling to free handlebars from wheels but I lay them top to tail - handlebars facing front on the bottom bike. Thanks 馃憤 is that in an A4 Advant?聽 I'm still wondering if I can fit them in my 4 door S5 with the seat laid down.聽 Not thought of laying the bikes down as opposed to standing then up 馃憤 Quote Link to comment Share on other sites More sharing options...
Shazzc Posted May 31 Share Posted May 31 (edited) It is an S4 Avant B9 but I imagine the dimensions are the same.聽 My partner has a 62 plate S5 and that also works but the low sloping glass window at the very back does require more fiddling.聽 Mind you these are road bikes (42cm wide handlebars). With the wheels off, it should be much easier.聽 Edited May 31 by Shazzc 1 Quote Link to comment Share on other sites More sharing options...
