Gregp Posted May 11, 2024 Posted May 11, 2024 Afternoon all, I'm doing some trouble shooting on my 2011 A6, C6, 2.7tdi - CANA engine code. On my diagnostics and that of an Audi independent the temperature before turbo is measuring 849°C, but there is no sensor before the turbo on the 2.7tdi (there is on the 3.0 tdi). Can anyone point out if this temperature is irrelevant / red herring or is the reading is calculated from another sensor or a resistor somewhere? I have replaced the temperature sensor on the EGR cooler to rule this out but no change there. The reason for looking into this was over the last 2 years the car has had DPF regeneration issues, resulting in me having the DPF professionally cleaned at Home - DPF Clean Team, EGR cooler cleaned by myself - a real pain to remove, injectors removed and tested (all ok) as well as other unrelated exhaust temperature sensor failures. Any advice greatly appreciated on where this temperature input comes. Thanks a lot.
