Please could someone help I have just bought an A5 Quattro 2008 3.0tdi 110 thousand miles has a whine from the gearbox in All gears doesn't fluctuate just a constant noise drives perfect gears easily change clutch is light as expected would an oil change help
If it's been bought from a dealer within the last 30 days then the dealer has the responsibility to fix it FOC or take the car back for a full refund.
No unfortunately a private purchase now not sure if it's coming from the gearbox or diff . thanks everyone for your help
Thanks Ian,
Please come back when you believe you have narrowed it down to a more specific location.
Differential noise can usually be made to alter by assessing whether the noise changes on smooth acceleration and decelerating.
p.s. please do not assume that a private purchase results in no comebacks. The vehicle must still be as described. That is why sellers now simply state ‘ Starts, stops, drives.’
