RyanM87 Posted May 12, 2024 Posted May 12, 2024 Looking to lower my A4 purely to get rid of some of the arch gap, so probably 20mm drop on current S/line suspension. Am I right in saying a 35/40mm set of springs would do the job?
Stevey Y Posted May 12, 2024 Posted May 12, 2024 3 hours ago, RyanM87 said: Looking to lower my A4 purely to get rid of some of the arch gap, so probably 20mm drop on current S/line suspension. Am I right in saying a 35/40mm set of springs would do the job? Hi in theory that would bring the whole lot right down as the S Line is 25mm lower than standard, not sure how much extra strain will be put on the bushes on the suspension itself but best policy would be get it on a old fashioned hydraulic ramp after fitting spring and with the car at its ride height slacken off the bush locking bolts and then re tighten, then get the alignment done on a Hunter 4 wheel alignment system to adjust the castor and camber to prevent erratic tyre wear. Steve.
