Benn Brown Posted May 20, 2024 Posted May 20, 2024 2014 A3 TFSI 80K FSH. When I open the door the engine fan starts no key in ignition goes for a while then stops no fault lights runs fine just weird any thoughts?.
Steve Q Posted May 20, 2024 Posted May 20, 2024 With any odd electrical gremlins I look at the battery as the first port of call. As a failing battery can cause the electrical systems to play up.
flatoutflatbroke Posted May 20, 2024 Posted May 20, 2024 My fan keeps coming on too, even a 10 minute drive can put the fan on for 5 minutes or so, doesn't do it everytime though
benns54321 Posted May 22, 2024 Posted May 22, 2024 Came on again after starting engine then goes off after awhile just need to know if I should be concerned or not/ battery is fine.
