Hi
Is it possible to switch off auto windscreen wipers on my A4 B7?
 I have had several different cars with auto wipers and none of them work.
Either one wipe every three days or ten every second, well a slight exaggeration but you know what I mean.
I guess the sensor is in the back of the mirror housing. What if I tape over it.
3 hours ago, WhisperingAl said:
Hi
Hi if you tape over it the thing will work all the time as it works on opacity so the more its blocked the harder it works, this is quite a common problem on A4/A6 2012 up and is usually down to a cruddy control stalk on the steering wheel which is why there are so many second hand units for sale, you have to replace the whole unit which is a bit of a mission especially when you replace it as if you have not placed the squib ring in dead centre the steering goes bananas, try cleaning it with contact cleaner first.
  • 2 months later...
