NFIN02 Posted May 24, 2024 Posted May 24, 2024 My a6 occasionally goes into limp mode with flashing coil light. When car is stopped and left a few minutes it appears to reset and go back to normal. I have scanned and found 2 faults - p200200 and p23700. Advice appreciated please
Steve Q Posted May 25, 2024 Posted May 25, 2024 Any black smoke? If so could be a blocked dpf. Is there any lag or whine from the turbo?
Stevey Y Posted May 25, 2024 Posted May 25, 2024 22 hours ago, NFIN02 said: My a6 occasionally goes into limp mode with flashing coil light. When car is stopped and left a few minutes it appears to reset and go back to normal. I have scanned and found 2 faults - p200200 and p23700. Advice appreciated please Hi P2002 is the low pressure EGR cooler have a look on the site archives this is well documented the cooler gets blocked with adblue crystals and fails its a horror to replace its not the parts so much as the labour charges, the other one is the MAP sensor which is cheap and easy to change.
