bran Posted May 25, 2024 Posted May 25, 2024 Hi everyone my a4 3.0 s line goes into limp mode at least once a week. I had the car plugged in and it threw up these fault codes. Are they all connected and are they relatively easy fixes? Many thanks bran
Stevey Y Posted May 25, 2024 Posted May 25, 2024 17 minutes ago, bran said: Hi everyone my a4 3.0 s line goes into limp mode at least once a week. I had the car plugged in and it threw up these fault codes. Are they all connected and are they relatively easy fixes? Many thanks bran Hi yes can be fixed and yes thy are connected, new glow plugs required, I would get a delete kit for the swirl flaps inside the inlet manifold and see if that cures the boost pressure control unit on the turbo if not you may well need a new turbo. Steve.
