Pande98 Posted June 2 Share Posted June 2 Hello team, I'm experiencing this issue quite a time. When driving the coolant alarm goes on and flashes, this happens at random times. The car does not overheat and the coolant level is normal. I have changed the temperature sensors as I thought that was causing the issue but the problem remains. Also there are no errors running a diagnostic check. If someone knows anything I would appreciate it. Quote Link to comment Share on other sites More sharing options...
