Dennis Gallagher Posted June 2 Share Posted June 2 My rear window washer is not working, just wondered if anyone else has the same problem. Any ideas on what it may be. Only had the car 2 weeks a4 avant b9 2017. Quote Link to comment Share on other sites More sharing options...
ThomasG Posted June 2 Share Posted June 2 Can you hear the pump? Mine gets blocked. Pull it off an stick a pin in 馃檪 Quote Link to comment Share on other sites More sharing options...
Dennis Gallagher Posted June 2 Author Share Posted June 2 Yes I can hear the pump, will try a pin,thanks.聽 Quote Link to comment Share on other sites More sharing options...
Magnet Posted June 3 Share Posted June 3 Hello Dennis, Also consider the possibility of the tubing having broken at the tailgate junction, or similar (usually during a cold spell) and water now being sprayed within the tailgate.聽 Of course, well worth checking that fluid does perhaps get to the 聽jet - as has been suggested- 聽to eliminate the likely chances that it鈥檚 just a blocked jet issue.聽 Perhaps you would let us know how you get on.聽 Kind regards, Gareth.聽 Quote Link to comment Share on other sites More sharing options...
Dennis Gallagher Posted June 3 Author Share Posted June 3 Thanks for the info, will definitely let you know how I get on.聽 1 Quote Link to comment Share on other sites More sharing options...
Anton8 Posted June 3 Share Posted June 3 Hi I had this on my A6 Avant. The pipe had come off inside the tail gate. If the clips that hold the tail gate trim on are anything like the A6, they are very fierce and they distort when you try to put the trim back. Might be an idea to have some spares before you do the job Tony 1 Quote Link to comment Share on other sites More sharing options...
Dennis Gallagher Posted June 3 Author Share Posted June 3 Hi thanks for the info.聽 Quote Link to comment Share on other sites More sharing options...
