Rear washer not working
Hello Dennis,
Also consider the possibility of the tubing having broken at the tailgate junction, or similar (usually during a cold spell) and water now being sprayed within the tailgate.聽
Of course, well worth checking that fluid does perhaps get to the 聽jet - as has been suggested- 聽to eliminate the likely chances that it鈥檚 just a blocked jet issue.聽
Perhaps you would let us know how you get on.聽
Gareth.聽
Hi
I had this on my A6 Avant. The pipe had come off inside the tail gate. If the clips that hold the tail gate trim on are anything like the A6, they are very fierce and they distort when you try to put the trim back. Might be an idea to have some spares before you do the job
Tony
  • Thanks 1
聽 Only 75 emoji are allowed.
聽Share
