JoThornton Posted June 3, 2024 Posted June 3, 2024 I have had my Audi Q4 etron for 4 months. I have the Ohme charger. It was working fine using Ohme app to schedule charging at the most efficient times as per my electricity EV tariff. I suddenly had an issue with it not charging properly and ended up doing a full factory reset on my car. Since then the car will only charge as per what the car tells it to do and not the Ohme app. I’ve turned off all the timers on the car/audi app but it still will not revert to using the Ohme scheduling. I’ve reset the charger, done a soft reset in the car. Checked everything I can on Ohme app / Audi app and the car itself. I’ve spoken to Audi dealership Audi Ev support and Ohme and none of them seem to be able to help, they all told me to turn off the schedule in the car which I have done already.. has anybody else had this issue? Am i missing anything obvious? I’ve spent hours googling and also going through all the settings and just can’t figure it out
Anton8 Posted June 4, 2024 Posted June 4, 2024 Hi Joanne I haven't had your problem, but I had a few problems regarding the set-up on the MMI. I got on to the Audi Help Line and they were able to take the MMI over and sorted it out for me. On a one to one basis, they sent me a link so that using my mobile phone as a camera so they could see what was on the screen and then they were able to guide me through the system and sort the problem. I hope you get it resolved. Tony
cliffcoggin Posted June 4, 2024 Posted June 4, 2024 Joanne. You can test the Ohme charge point by setting the schedule on its panel. That should tell you if the app/wifi/mobile part of the connection is at fault.
Emma K Posted November 10, 2024 Posted November 10, 2024 Morning Jo, I'm not sure if you are still having the same issue, but it sounds like you're experiencing the same issues as I've had. I've had a lot of back-and-forth with Ohme, and they are saying that the Audi app isn't compatible with Ohme—which begs the question: Why are Audi recommending Ohme if there's a known fault? To help fix the issue, they've suggested unpairing the car from the Ohme app, doing a hard reboot (basically switching it off at the mains, waiting 15 mins and then switching back on and then continuing without an account). Here's the info they've sent me... We have recently become aware that there is an issue affecting Audi API functionalities. Our Product team is currently investigating this issue and will look to resolve this as soon as possible. As an Ohme Labs feature, communication directly through your vehicle (via API) is still in development. As a result, it may not work as intended from time to time. For the moment you would need to disconnect the API link (by clicking Continue Without Account after selecting your car make) and then adjust your charge schedule slightly to 'add' a certain amount of charge rather than meeting a 'target'. There is more information about how to charge without API support in our support article below: How do I choose the right schedule for my car? We're sorry for the inconvenience this may cause. I hope this helps and good luck! Emma
colincar Posted February 9 Posted February 9 Hi, I am having loads of trouble with my ohme charger, the mileage on the audi app compared to ohme app do not tally up. I have to reboot the charger then unpair and pair my vehicle, it then tally's up and will charge normally. But I have to do this virtually every charge as it will charge, but start charging straightaway instead of waiting till 11.30pm, because the Ohme app shows 0 miles or near 0. Ohme said they know about the issue, but I feel its not fit for purpose Audi Q4 40 S Line 2023
