benns54321 Posted June 11, 2024 Posted June 11, 2024 My 2013 a3 tfsi fan has got worse keeps coming on quite loud even if I just open the door it comes on temperature is normal should I be worried.
cliffcoggin Posted June 11, 2024 Posted June 11, 2024 23 minutes ago, benns54321 said: temperature is normal should I be worried. Yes you should, though it is not clear to me if you refer to the engine fan or the cabin fan. The fan will knock it self out by continually running at high speed, and will increase fuel consumption a little. 1
Stevey Y Posted June 11, 2024 Posted June 11, 2024 37 minutes ago, benns54321 said: My 2013 a3 tfsi fan has got worse keeps coming on quite loud even if I just open the door it comes on temperature is normal should I be worried. Hi its either the temperature sensor that controls the fan or most likely the fan control unit mounted on the fan assembly in front of the radiator. Steve.
benns54321 Posted June 11, 2024 Author Posted June 11, 2024 Thanks guys. I will probably have to have code check done to see what faults it brings up I think That's about £100 or is there an easier way?.
Stevey Y Posted June 11, 2024 Posted June 11, 2024 8 minutes ago, benns54321 said: Thanks guys. I will probably have to have code check done to see what faults it brings up I think That's about £100 or is there an easier way?. Hi yes spend your money on an OBD Eleven reader then you can look at what you want whenever you want on your phone and not become a victim of overcharging garages, you will be able to tell them what the problem is. Steve.
benns54321 Posted June 12, 2024 Author Posted June 12, 2024 Thanks guys. I will get hold of one of these and give it a go thanks for all your help.
