BetterZoomHome Posted Monday at 02:09 PM Share Posted Monday at 02:09 PM Love my new (2023 plate) Q3 TFSI-e apart from one thing - the accelerator is so sensitive/not-stiff that I can't just rest my foot on it without speed slowly increasing - this is more of a pain for lower speeds. I am using cruise control and experimenting with seat position and only having the tip of my foot on it, but is there a way to just make it less sensitive somehow? Quote Link to comment Share on other sites More sharing options...
WhisperingAl Posted yesterday at 11:26 AM Share Posted yesterday at 11:26 AM I have the same issue on my old A4 B7. The slightest touch on the pedal accelerates, even a slight bump in the road. I assume it is a “fly by wire” accelerator as I cannot see a cable. Perhaps it is adjustable by VAGCOM. Quote Link to comment Share on other sites More sharing options...
BetterZoomHome Posted yesterday at 12:56 PM Author Share Posted yesterday at 12:56 PM Interesting. Maybe - is that something a dealer could investigate I wonder? Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted yesterday at 01:53 PM Share Posted yesterday at 01:53 PM 53 minutes ago, BetterZoomHome said: Interesting. Maybe - is that something a dealer could investigate I wonder? Hi its probably the TPS on the pedal has some wear have you plugged it in for faults you can usually find what's wrong with the pedal sensor on live data as if you hold the pedal in one position you can see the voltage disc moving on its own. Quote Link to comment Share on other sites More sharing options...
BetterZoomHome Posted yesterday at 02:13 PM Author Share Posted yesterday at 02:13 PM I only just got the car - my first Audi 🙂 - can I or should I buy this VAGCOM thing so I can check this out? Or do dealers have this? Thanks! Quote Link to comment Share on other sites More sharing options...
WhisperingAl Posted yesterday at 02:27 PM Share Posted yesterday at 02:27 PM I only have a cheap ODB reader so cannot check live data. I thought about buying VAGCOM but I only run Mac at home. 1 hour ago, BetterZoomHome said: Interesting. Maybe - is that something a dealer could investigate I wonder? I have the same issue on my old A4 B7. The slightest touch on the pedal accelerates, even a slight bump in the road. I assume it is a “fly by wire” accelerator as I cannot see a cable. Perhaps it is adjustable by VAGCOM. Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted yesterday at 02:53 PM Share Posted yesterday at 02:53 PM 16 minutes ago, WhisperingAl said: I only have a cheap ODB reader so cannot check live data. I thought about buying VAGCOM but I only run Mac at home. I have the same issue on my old A4 B7. The slightest touch on the pedal accelerates, even a slight bump in the road. I assume it is a “fly by wire” accelerator as I cannot see a cable. Perhaps it is adjustable by VAGCOM. Hi have any of your relatives got an old Dell or IBM they want to get rid of thats how I run mine and to be honest when I got it I have not been anywhere near a dealers since 2019 and if I am honest between VCDS and OBD Eleven there is not much you can't do yourself both systems have saved me a fortune probably six times what I paid for both systems and the handy bit about OBD is you can keep it in the glovebox, its tiny, for when you are out on the road as it runs on your phone. Steve. Quote Link to comment Share on other sites More sharing options...
WhisperingAl Posted yesterday at 03:07 PM Share Posted yesterday at 03:07 PM Ok. Thinking about that. Thanks Quote Link to comment Share on other sites More sharing options...
