photon Posted July 2 Posted July 2 Driving in Greek Mountains on dirt track using "Allroad" setting when a warning message beeped " Suspension Too Low" Stopped, examined and found all look fine with good ground clearance. 5 minutes later the rear N/S airbag exploded with a shotgun strength bang ! Now the rear suspension was down with only minimal ground clearance quite insufficient for the terrain resulting in damage to rear undersides and worse, a significant fear that we would not be able to get out of the dirt road network to a more level tarmac surface. This problem and subsequent damage to a low-mileage 2014 A6C74G Allroad was caused by a snapped plastic drop link or rod connecting the level-sensor to the rear N/S suspension. The CPU thinks the car is too low, tries to further inflate the air-spring and the explosion results, potentially stranding me in uninhabited mountains. Now I have the car on the ramp. One knackered airbag with no stock in Greece other than £800 from the stealership, and damaged to the rear skirt and underbody parts all because of a "weak link" Examination of the other three links reveals that two are already bent and will doubtless stress-fail in due course. Anyone else had the same problem? I urge owners to check and replace these links although at the moment I cannot locate a source, only the complete sensor and link kit at £80 a corner. Totally p***ed off and cross? yes, but grateful to be able to drag the A6 !Removed! over rocks and scree using 150kW of engine. Thinking of fabricating a better substitute, certainly, unless others have beaten me too it.
Steve Q Posted July 3 Posted July 3 Sorry to hear this. Shocking that plastic is being used for such an important component
K3v Posted July 7 Posted July 7 Sorry to hear of your problem I have an allroad and touch wood no problems with mine although I've never taken it off road. I think I've seen replacement metal ones for sale which allow adjustment in the ride height if wanted. 1
