There is a noise when i accelerate,  sort of a chain spinning on a cog .
Hi little more info like where it seems to be coming from might draw more response.
Just when i push down on accelerator about an inch and not sure location,  but if u ever peddled backwards on a oush bike thats tge sort of noise. Sorry bit vague
Hi it could be the dmf rattling the clutch slave cylinder bearing or even a driveshaft C.V. joint, could also be a stone lodged between the backplate and a disc, thats just a few of the variables, take it to a garage and get them to test drive it they may have a diagnosis.
  • Thanks 1
  • 2 months later...
That's most likely the HPFP.
It's normal if it reducess when you stop accelerating
What is a HPFP? It's not an abbreviation I am familiar with.
hi cliff.id say hes talking about the high pressure fuel pump.Greg
