Mr G Posted July 5, 2024 Posted July 5, 2024 Hi all, I am potentially looking at a few A3's this weekend, around the 2017 model, both hatch and saloon editions, 1.5 TFSI CoD. I have a few questions and queries I need help with please. - Are these belt or chain driven? - What common problems do they have? - Is there anything particular I should look for? - What does ongoing maintenance look like? Service, known faults, preventative maintenance? - What is the fuel economy like? - Do they have DAB and USB Audio input as standard? Many thanks in advance.
cliffcoggin Posted July 16, 2024 Posted July 16, 2024 I have no specific knowledge of those models, however the information you seek should be readily available on the internet, which is probably why nobody replied earlier.
EDQ Posted July 16, 2024 Posted July 16, 2024 (edited) I've very recently bought one of these of the same year. I can answer some but probably not all of your questions to some degree. 1. 2017 if it is the FL model is belt driven. Mine has done 66k. I phoned my local Audi dealership and they said it won't need to be done. They changed the service interval from a set mileage and 5 years (whatever comes first) to just a mileage of, and don't quote me on this as it's from memory, around 122k miles. Decision whether to change according to their previous advice (lower mileage or 5 years whatever comes first) is up to your own discretion. Belts have improved no end nowadays. Personally, I'll leave mine until about 100k miles and change then. 2. Thankfully no problems with mine. Just the usual service items needing doing like filters and plugs. 3. I'd look for as much Audi or independent specialist service history as possible. Ask the seller for a print out of the Audi service history or receipts from independents or previous owners. I'd also take your time choosing one. There's plenty out there. 4. I like to do preventative maintenance myself. The pollen and air filter are very easy to do. Finished those. I expect the fuel filter is an unscrew old and fit new easy job too. Spark plugs are a different issue. It's tight under the engine bay despite there being bigger engine variants of the same body type. Basically, I am changing the core renewables anyway just to reset the clock on them and then will replace in the future according to my fitment of them now. 5. Fuel economy looks good thus far. I am not one for noting mpg figures but it appears very economical to me over the few hundred miles I've driven it thus far. 6. I have both DAB and USB. Mine is a S-line model but has very few options, so judging by this only, on this trim I think it would be standard. Unsure about the SE and Sport trims though. Can't really be much help other than that, I'm afraid. Someone more knowledgeable than me that has had their car longer may be able to add advice or give better. Best of luck with the car search if you haven't found one already! Edited July 16, 2024 by EDQ 1
EDQ Posted July 17, 2024 Posted July 17, 2024 23 hours ago, Mr G said: That is actually so helpful. Thank you. 👌 👍
