Davidacarrick Posted July 7 Share Posted July 7 Hi Does anyone with a a6 c7 2.0 tdi 190 with dual zone climate control and VCDS be able to send me a scan of their Auto HVAC module / engine module coding? Looking to see if my modules have the correct settings/parameters setup on the cooling system/fan control module. still getting heater support pump locked (intermittent) then sometimes throws up engine management light. Don’t see any obvious coolant loss or leaks. Pump runs when tested and looking to see if it could be a setting/parameter fault before looking to change out fan control module. Quote Link to comment Share on other sites More sharing options...
