Hi guys
can anyone help please
I’ve recently purchased an a3 2015
When I put the indicators on the front fog lights also flash ( out of sequence)
how can I turn this off please
thank you
I'd recommend a diagnostic check to see if any fault codes flag up but could be an issue with the headlight switch or hazard switch.
It could be a bad earth connection at one of the light units. Such faults can be difficult to find and correct unless you have experience of car electrical systems.
I think it’s more something they have programmed it to do 😞
Hi its definitely a bad earth or a short to ground, best thing to do is get the car scanned for faults which will pinpoint where its going wrong.
it’s both sides that do it 🤷‍♀️
