Wooliefromwales Posted July 12 Share Posted July 12 Hello Chaps, etc. I own an A4 1.8t and a March 2013 A3 1.4TFSi (...8V8DA...). Both undramatic and easy to own, however, after a bit of drama with some mud on the road I have mashed the bottom of the rad(s) on the A3. I have stripped the front of the car and removed the rads. Ordered replacements using the VIN. A/C rad if fine but the cooling rad is completely different from the one I removed. Mine is a double rad whereas the new one is single. Supplying company says that it is correct according to the VIN. Clearly, it's not. Looking everywhere, I can only see a range of single rads. Anyone point me in the right direction or am I off to the breakers yard? Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted July 12 Share Posted July 12 5 hours ago, Wooliefromwales said: Hello Chaps, etc. I own an A4 1.8t and a March 2013 A3 1.4TFSi (...8V8DA...). Both undramatic and easy to own, however, after a bit of drama with some mud on the road I have mashed the bottom of the rad(s) on the A3. I have stripped the front of the car and removed the rads. Ordered replacements using the VIN. A/C rad if fine but the cooling rad is completely different from the one I removed. Mine is a double rad whereas the new one is single. Supplying company says that it is correct according to the VIN. Clearly, it's not. Looking everywhere, I can only see a range of single rads. Anyone point me in the right direction or am I off to the breakers yard? Hi if you could post a picture of the original that would be a great help. Steve. Quote Link to comment Share on other sites More sharing options...
Wooliefromwales Posted July 12 Author Share Posted July 12 Hi Steve, this is what came out Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted July 13 Share Posted July 13 22 hours ago, Wooliefromwales said: Hi Steve, this is what came out Hi dont know what the new one looks like but went fishing on the net and found loads of those on Autodoc and other sites they are quite common so if the new one looks nothing like it reject it, as I said plenty of them available for sub £100 for a Nissens unit which were O.E. anyway, please let us know how you get on. Steve. Quote Link to comment Share on other sites More sharing options...
