Kog Posted July 15 Share Posted July 15 Hi all new to this site I have a4 b7 2.0tdi cabriolet I have glow plug light blinking wich suggests problem with partial blockage on Dpf I was going to spray cleaner down exaust pressure sensor pipe but there are two pipes coming from this any idea wich pipe I use any help greatly appreciated thanks in advance Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted July 15 Share Posted July 15 2 hours ago, Kog said: Hi all new to this site I have a4 b7 2.0tdi cabriolet I have glow plug light blinking wich suggests problem with partial blockage on Dpf I was going to spray cleaner down exaust pressure sensor pipe but there are two pipes coming from this any idea wich pipe I use any help greatly appreciated thanks in advance Hi like the term suggests, without a proper diagnostic scan you are guessing, it could be turbo over, boost, a glow plug, a drop in fuel rail pressure, MAFF/MAP failure, what leads you to the conclusion that its the DPF?. Steve. Quote Link to comment Share on other sites More sharing options...
Kog Posted July 15 Author Share Posted July 15 Hi catalyst symbol came up blinking then by time I got to garage stayed on so added some Dpf additive drove at high revs for 30 miles then cat symbol went off along with traction symbol now I’m just left with blinking glow plug light and after research and speaking to several mobile Dpf mechanics they suggest it needs cleaning so thought it might be worth a gamble at spraying some cleaning foam down wich ever pipe it is also change fuel filter to rule out cheapest first Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted July 16 Share Posted July 16 19 hours ago, Kog said: Hi catalyst symbol came up blinking then by time I got to garage stayed on so added some Dpf additive drove at high revs for 30 miles then cat symbol went off along with traction symbol now I’m just left with blinking glow plug light and after research and speaking to several mobile Dpf mechanics they suggest it needs cleaning so thought it might be worth a gamble at spraying some cleaning foam down wich ever pipe it is also change fuel filter to rule out cheapest first Hi personally I would still get it scanned as both those lights really are separate entities as the cat symbol covers that alone and the glow plug light covers a multitude of sins and paying for a clean that you dont need. Steve. Quote Link to comment Share on other sites More sharing options...
Kog Posted July 18 Author Share Posted July 18 Hi I managed to get hold on vag code reader will have a play later see what happens but thanks for reply 1 Quote Link to comment Share on other sites More sharing options...
Kog Posted July 18 Author Share Posted July 18 (edited) Fault code 01393 is only code I have googled it says brake pedal switch am I wright any help appreciated thanks Edited July 18 by Kog Quote Link to comment Share on other sites More sharing options...
Kog Posted July 18 Author Share Posted July 18 (edited) Please help thanks Edited July 18 by Kog Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted July 19 Share Posted July 19 21 hours ago, Kog said: Fault code 01393 is only code I have googled it says brake pedal switch am I wright any help appreciated thanks Hi yes its the switch on the pedal, it could also be the brake light bulbs so check to see if working from the research I have done it appears the switch is a common failure. Steve. 1 Quote Link to comment Share on other sites More sharing options...
Kog Posted July 20 Author Share Posted July 20 Thank you for reply I have cleaned and checked all bulbs working so will have to try replacing switch do you know if there is a link to a video and any recommendations as to were I purchase one thanks Quote Link to comment Share on other sites More sharing options...
Solution Stevey Y Posted July 20 Solution Share Posted July 20 7 hours ago, Kog said: Thank you for reply I have cleaned and checked all bulbs working so will have to try replacing switch do you know if there is a link to a video and any recommendations as to were I purchase one thanks Hi go on a site called ZAP 7 and put in your VIN that should bring up a parts catalogue for your car, the part number is the key to getting the right part and YouTube is the best source of how to if you are unsure how to fit the part. Steve. Quote Link to comment Share on other sites More sharing options...
Kog Posted August 6 Author Share Posted August 6 Hi mate sorry for late reply and thanks for above information I got new part fitted cleared codes took car for a run and now all lights are off rechecked to see if any codes and there isn’t any thanks for help much appreciated 1 Quote Link to comment Share on other sites More sharing options...
