Cookieboy Posted July 18 Share Posted July 18 2018 A3 TFSI Hatch rear washer not working, have replavef jet module but still not functional. Very small amount of water comes from washer unit with jet module removed but not enough to even resch rear screen. Any suggestions for a fix ?? Quote Link to comment Share on other sites More sharing options...
Magnet Posted July 19 Share Posted July 19 Welcome Gary, and thanks for joining. If you aren’t getting a good supply to the jet, have you checked the reservoir outlet for partial blockage? Washer reservoirs are very prone to generating undesirable ‘goo’ which restricts the flow by partially blocking the feed. Also possibility of a partial fracture in the tube due to flexing where the boot opens and closes -? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted July 19 Share Posted July 19 In addition to Gareth's suggestion of a broken pipe, check the rear wiper motor for leaks. The water runs through the motor and has been known to leak past defective seals. Quote Link to comment Share on other sites More sharing options...
