RevolvingSteve Posted July 22 Posted July 22 I am experiencing a very strange noise, specifically when the suspension drops suddenly (driving off a speed hump or going over a crest). It makes a very quick 'Whup / Whoop' noise, it seems to be coming from the front but seems to move from side to side. It does have the allroad air suspension, does anyone have a similar experience?
Steve Q Posted July 23 Posted July 23 I'd recommend getting the system checked asap but it could be suspension arms instead of a airbag etc.
Nahpets Posted November 8 Posted November 8 On 7/22/2024 at 5:24 PM, RevolvingSteve said: I am experiencing a very strange noise, specifically when the suspension drops suddenly (driving off a speed hump or going over a crest). It makes a very quick 'Whup / Whoop' noise, it seems to be coming from the front but seems to move from side to side. It does have the allroad air suspension, does anyone have a similar experience? Hi, have you found out what the problem was? I’m experiencing the same problem. I own a Audi A6 C7 quattro. Thanks in advance 🙂 Greetings, Stephan
cliffcoggin Posted November 11 Posted November 11 Stephan. You won't get a reply from Rolling Steve. He has not been back to the forum since he wrote his question. You would do better to create your own topic in the hope that it might be answered by others.
RevolvingSteve Posted November 11 Author Posted November 11 On 11/8/2024 at 1:30 PM, Nahpets said: Hi, have you found out what the problem was? I’m experiencing the same problem. I own a Audi A6 C7 quattro. Thanks in advance 🙂 Greetings, Stephan Hi Stephan, I haven’t ‘solved’ it, but I spoke with the original owner and he said it started making the noise when the rear airbags were fitted, which are aftermarket ones. I will get them to check bushes etc next time it has a service, but suspect it’s down to those and I won’t be changing them. Any similarly with your situation?
