Stuart11 Posted July 22 Posted July 22 Has anyone used OBD Eleven tool for S3. Looking to change some of the features and add full beam assist. Would it cause problems to the car?
Mark R1 Posted July 22 Posted July 22 Hi, I have used on my 2020 S3 8V but only to turn off the rear lights DRL function. Easy to use and no problems.
Mark R1 Posted July 25 Posted July 25 Hi, purchased from Amazon for about £70. You do then need to purchase credits within the app to make changes and I paid £20 which is more than I needed but good to have in hand. I also turned off the fake engine noise and dimmed the hazard switch.
Stuart11 Posted July 25 Author Posted July 25 Thank you for this info. Looking to add main beam assist, not sure if has built in ambient lighting inside doors.
Mark R1 Posted July 25 Posted July 25 Hi, my car does not have ambient lighting but I did add puddle lights to both front and rear doors which did not require OBD11, just plug and play as long as you have leds in the bottom of your door cards.
enc Posted August 14 Posted August 14 (edited) So many of these OBD readers about. It’s confusing which does what 🤔😂 Edited August 14 by enc
Stuart11 Posted August 14 Author Posted August 14 Your right there are a lot even some people are talking about Carly OBD’s they are better than OBD Eleven's. I’m just after something that I can add extras to the car
