Mr G Posted July 23 Posted July 23 Hi guys, Why would both sidelights not work on an A3,2017, non-S Line. Main beam, and high beam work OK, just the sidelights dont work. Could it be fuse? Bulbs look OK on visual inspection. Where is the fuse box and and what number fuse would it be? Thanks.
Steve Q Posted July 23 Posted July 23 Could be the light switch itself. Id recommend a diagnostic check to see if any fault codes flag up
cliffcoggin Posted July 23 Posted July 23 If I recall correctly each sidelight has a separate fuse, so the problem is more likely to be the switch. Fuse and fusebox locations will be in the car handbook if such things exist still.
Mr G Posted July 23 Author Posted July 23 I found the fuse box, but for the life of me couldn't work out which fuses to check.
Mr G Posted July 23 Author Posted July 23 It's the bulbs in this picture that isn't working (both sides). That is the sidelight bulb, right?
Solution Mr G Posted August 22 Author Solution Posted August 22 I think I confused myself somewhat, being a total Audi rookie. So the sidelights are apparently the DRL's, and the bulb I was querying is run by some weird switch for rain lighting????? 1
cliffcoggin Posted August 22 Posted August 22 So did you get the sidelights to work? I've never heard of rain lighting. Can you explain further?
Mr G Posted August 22 Author Posted August 22 6 minutes ago, cliffcoggin said: So did you get the sidelights to work? I've never heard of rain lighting. Can you explain further? I am new to A3's, so this is the button I refer to.... .
oake Posted August 23 Posted August 23 Apparently, the button you've indicated applies only to cars with LED headlights.
Mr G Posted August 23 Author Posted August 23 Interested, thanks Steve. So do I just put them on during night and rain?
oake Posted August 23 Posted August 23 57 minutes ago, Mr G said: Interested, thanks Steve. So do I just put them on during night and rain? I don't have LED headlights, and my button therefore doesn't do anything, so I can't really help you. I just quoted the relevant passage from my handbook. If you have LED headlights, I guess you could experiment to see what they do. 1
