DJO Posted August 10, 2024 Posted August 10, 2024 Hi, Recently picked up my first Audi, 2015 A4 Avant diesel. So far driven it about 600 miles and enjoying very much. Only niggle I can find with it is the window washers. Front passenger side is very sluggish and rear window just shows a little dribble around the jet. Any tips? Cheers David
Anton8 Posted August 10, 2024 Posted August 10, 2024 Hi David Sounds like blocked jets. They need cleaning out as dirt and grit can get into them. Definitely attend to the rear washer, if that gets blocked in can blow the supply pipe off. Which means that the tailgate trim would have to be removed and that is not easy, and BTW Hello. Tony 1 1
DJO Posted August 10, 2024 Author Posted August 10, 2024 Thanks Tony, I will have a look, I am guessing maybe a small pin in the jet to unblock?
cliffcoggin Posted August 10, 2024 Posted August 10, 2024 You might be lucky in pricking the jets with a pin, but it is possible the blockage will simply be pushed back up the pipe, only to be pushed forward into the jet again by the water. If that happens you will need to remove the jet and back flush it with water to get rid of the dirt. 1
DJO Posted August 10, 2024 Author Posted August 10, 2024 1 minute ago, cliffcoggin said: You might be lucky in pricking the jets with a pin, but it is possible the blockage will simply be pushed back up the pipe, only to be pushed forward into the jet again by the water. If that happens you will need to remove the jet and back flush it with water to get rid of the dirt. Thank you. How would I remove the jet, does the wiper arm come off to reveal them? Now a Haynes manual or similar for this car would be helpful!
cliffcoggin Posted August 10, 2024 Posted August 10, 2024 3 hours ago, DJO said: How would I remove the jet, does the wiper arm come off to reveal them? Sorry, I have no idea.
DJO Posted yesterday at 12:54 PM Author Posted yesterday at 12:54 PM I thought I'd give an update. The cover at the base of the wiper arm unclips and I found my nozzle jet fell out. I confirmed that with the jet off, water was flowing. The little nozzle jet thing you can pick up a pair of for under £5 on eBay. Problem solved!
DJO Posted yesterday at 04:00 PM Author Posted yesterday at 04:00 PM 1 hour ago, alpha omega said: glad you sorted it Thank you! Now I have to figure out why the satnav has stopped working. 😂
