Hello folks
                 I have recently taken ownership of a (73) A3 sport, on picking it up from the dealership my phone was paired but I used a cable as I was unsure of the roads, etc. Once home I've tried just going wireless but it is very frustrating as I set off it may work then I get out of the car and return moments later and it won't connect saying Bluetooth connection cannot be established.  It seems very hit and miss so I have to return to cable while driving 馃槙
 can anyone advise me on how to get a stable connection ?? Samsung A54
Kind regards
LB馃檪
  • 1 month later...
Switch off your WiFi on the car and try reconnecting via Bluetooth.  It should connect and then give an instruction "Do you want to activate WiFi Connection" or words to that effect.  Then select yes and you should be good to go.
  • Thanks 1
Expand
Thank you GregDeR7 that seems to have done the trick, appreciated馃檪
  • 5 months later...
I have similar with a Samsung S23 Ultra.  From "cold" always connects first time via wireless.  But won't automatically reconnect when "warm" (after a few minutes to an hour or so).  I have found that toggling bluetooth on the phone (off then on) seems to clear the issue and it reconnects.  Irritating and I'm hoping an updated will fix in due course.
