Hi just bought a 2012 audi a5 convertible. Is there an interface lead that will connect to my Samsung S21+ for android car play please?
Sorry you aren’t getting any responses so far Steve.
Have you tried local specialists for the advice you need?
Hi Steve - are you looking for the interface that plugs into the unit in the glove box?
If so, I think it's called the Audi Music Interface - it will let you play music from your phone though your stereo (MMI).
There are also ones for iPods etc.
I'm not sure if your bluetooth spec allows you to stream - it may only be phone call enabled.
Anyway if you google anything like "Audi AMI MMI cable" you'll see the choice, I suspect something like this or this might be the best options
Thank you so much for your response. Tried one from eBay and no luck luckily got refund
I had a Ford Ranger 2017 and al you did was use a usb and car andriod kicked in lol
Loving the A5 Cab in YShiraz Red
I think that there's only been 3 A5 generations and the second one from 2017 had the usb.
The ami cable should give you some additional functionality - my earlier VW so did.
You might also want to check your phone set up for USB.
