arsenalisa Posted August 27, 2024 Posted August 27, 2024 Hi all, I have recently purchased an S3 2022, and the tyre pressure is much lower than what is on the guide sticker by the drivers door. I like comfort mode but am unsure what the tyre pressure should be, any advice please?
Magnet Posted August 27, 2024 Posted August 27, 2024 Welcome Lisa, An approach which I think is logical:- (1) Look at the door sticker and check the tyres fitted to the car are the same as that on the sticker - for your wheel diameter. (2) Check the marking on the tyres to see if they are marked XL or not. (3) Check and note the brand/ brands of tyres fitted. (4) Check the actual tyre pressures and record them. (5) Check the recommended tyre pressures on the sticker for hopefully your correct fitted tyres. (6) Report back on findings. Kind regards, Gareth.
arsenalisa Posted August 28, 2024 Author Posted August 28, 2024 Hello, Thank you for the reply Yes the wheels match the sticker exactly 235/35 R19 They say extra load, which I assume is the XL They are all the same Goodyear. From the garage They were around 34 or 36. The sticker says 38 and 41 Hence my confusion. I have put air in to these levels and want to know if I have done the right thing. Kind regards Lisa
Magnet Posted August 28, 2024 Posted August 28, 2024 You most certainly have done the right thing Lisa. Tyre pressures should always be set to the manufacturer’s specification. OK, pessimistic:- you will now suffer from harsher ride characteristics associated with large diameter wheels and ultra low tyre profiles. Tyre profiles as low as 35 usually dictate XL tyres, which are less flexible, and exaggerate that harsher ride. ‘Recently purchased….’ probably hold the clue why the tyre pressures at hand over were lower than recommended - the seller has attempted to improve ride quality for demonstration and sales advantage. Anyway, you have now done the right thing and corrected the pressures. Please let us know how you get on with it in the short term. Kind regards, Gareth. 1
cliffcoggin Posted August 28, 2024 Posted August 28, 2024 Yes you have done the right thing. You may even notice the steering is lighter now, even if the ride is a little firmer. 1 1
