larop241 Posted August 29, 2024 Posted August 29, 2024 Hello everyone, Just after some advice. CJCB engine No Faults Crank, No start issue Ling story short, it started but after third attempt to start is just cut out and now no starting at all. Vcds - No fault Crank speed 250-300 rpm Pressure on rail is a bit bouncing. Questions: What should be fuel pressure after fuel filter, ? HPFP ? No shavings in HFPF. Battery OK,
