Glow Plugs
Go to solution Solved by Fatbloke,
2 hours ago, DanHemingway said:
Hi,
Hopefully just a quick one, are the order of glow plugs from left to right, 1 2 3 4?
Tia
Hi it wont matter about the order there is none except if you have the one thats fatter than the rest with the knock sensor built in that definitely has to go in the same hole.
  • 4 weeks later...
  • Solution
Looking at the car from the front, from the left it's 1, 2, 3, 4.
1,2 and 4 are standard glow plugs. No. 3 is larger (more expensive) with a built in pressure sensor.
