Graham B Posted September 3 Share Posted September 3 My car suddenly cut out on me and will not start, recent new battery. All ignition lights come on and it turns over but does not fire. Any clues as to where I should investigate ? Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted September 3 Share Posted September 3 7 minutes ago, Graham B said: My car suddenly cut out on me and will not start, recent new battery. All ignition lights come on and it turns over but does not fire. Any clues as to where I should investigate ? Have the car scanned for faults, my guess is low fuel pressure. Steve. Quote Link to comment Share on other sites More sharing options...
Graham B Posted September 4 Author Share Posted September 4 I’ve plugged my diagnostic tool in but there is no signal from the OBD 2 port, what does this mean Quote Link to comment Share on other sites More sharing options...
Mar4ix Posted Thursday at 05:17 PM Share Posted Thursday at 05:17 PM On 9/4/2024 at 10:52 AM, Graham B said: I’ve plugged my diagnostic tool in but there is no signal from the OBD 2 port, what does this mean When switch on ignition (but not start) , does check engine sign gets illuminated? Do you see check engine symbol? Quote Link to comment Share on other sites More sharing options...
Graham B Posted Thursday at 05:21 PM Author Share Posted Thursday at 05:21 PM I think my OBD port is connected to the same fuse as the amplifier which is blown , also supply to radio is out , the fuse keeps blowing so there must be something wrong in the circuit . Quote Link to comment Share on other sites More sharing options...
Mar4ix Posted Thursday at 05:24 PM Share Posted Thursday at 05:24 PM Just now, Graham B said: I think my OBD port is connected to the same fuse as the amplifier which is blown , also supply to radio is out , the fuse keeps blowing so there must be something wrong in the circuit . Why I ask about check engine light, as it is directly connected to ECU, if it is not illuminated, that mean car is not controlled by ECU , and won't fire up, as ECU have no power. Disconnect amplifier. Replace fuse , see if it is solution. Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted Thursday at 06:18 PM Share Posted Thursday at 06:18 PM 53 minutes ago, Graham B said: I think my OBD port is connected to the same fuse as the amplifier which is blown , also supply to radio is out , the fuse keeps blowing so there must be something wrong in the circuit . I think it very unlikely that the same fuse serves the both the non-essential radio and the essential canbus system. You need to refer to a wiring diagram. Quote Link to comment Share on other sites More sharing options...
Graham B Posted Thursday at 09:20 PM Author Share Posted Thursday at 09:20 PM The wiring diagram in my Haynes manual has no reference to fuse 18 in engine bay Quote Link to comment Share on other sites More sharing options...
