Np.sanderson Posted September 4 Share Posted September 4 Sudden powersteering loss No fault codes or warning lights Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted September 4 Share Posted September 4 3 hours ago, Np.sanderson said: Sudden powersteering loss No fault codes or warning lights Hi check the connector to the power steering motor as they are prone to corrosion on the pins, then check the wiring from the plug up as far as possible for broken wires, even if you have to remove the loom wrapping its easily replaced, genuine loom tape on eBay is pretty cheap. Steve. 1 Quote Link to comment Share on other sites More sharing options...
Np.sanderson Posted September 4 Author Share Posted September 4 Cheers Steve I will try this and let you know 2 Quote Link to comment Share on other sites More sharing options...
Solution Np.sanderson Posted 2 hours ago Author Solution Share Posted 2 hours ago It was a battery issue connection was lost to ecu.my scanner is only a cheap one and didn't pick up the fault. 1 Quote Link to comment Share on other sites More sharing options...
