Rybrook Posted September 5 Share Posted September 5 Hi As the title really, I have a split on the hard line at the joint between the inlet manifold joins the bulkhead, had all sorts of lumpy idle problems. I bodged it with a silicone coupler from my nitro rc car exhaust, no more lumpy idle. Are the any issues with using a straight rubber brake hose rather than the brittle plastic one? Something like this https://www.wrightsautosupplies.co.uk/product/brake-servo-hose/ Cheers Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted September 5 Share Posted September 5 (edited) It will depend how thick the wall thickness of the new hose is. Vacuum hoses have either more rigid reinforcement than pressure hoses, or thicker walls, because it is easier for a hose to resist internal pressure than external pressure. Edited September 5 by cliffcoggin correction Quote Link to comment Share on other sites More sharing options...
Rybrook Posted September 5 Author Share Posted September 5 Yes, the hose I have linked to is the type that is usually on the servo press fit elbow. I just want to eliminate the hard line. Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted September 5 Share Posted September 5 2 minutes ago, Rybrook said: Yes, the hose I have linked to is the type that is usually on the servo press fit elbow. I just want to eliminate the hard line. Hi as long as the hose is armoured it should be fine, brake hose is ideal as it only expands under extreme pressure which you are never likely to get from servo air. Steve. Quote Link to comment Share on other sites More sharing options...
