Mortician Posted September 6, 2024 Posted September 6, 2024 Hey guys I recently had the dreaded oil pressure light come on at a stop light when engine was up to temp, I checked the oil level in the MMI and it said it was full, every time the light came on (low oil pressure) I would check the display and it was all okay. I had my OBD2 scanner plugged in and no codes, I checked throughout the day and no change, the next day it was reoccurring at every stop/ idle, I checked the oil level and it said low, the light came off and I checked again on the display and it was back to full, a few hours later there was no information about the oil, then it showed full only once again and then it hasn’t anymore to the date, I suspected a faulty oil pressure sensor so I went ahead and replaced it with a Duralast (brown) and it was still happening, I checked the sensor and it seemed like it was faulty and it was leaking as well, replaced it with a new one and it did the trick for about 45 minutes, I got a quart of oil in it and no lights on for about the same time but it came back on, although not as intermittent as before on every stop/ idle, it’s now doing it like every 2-3 stop/idles. I am now going to replace the blue sensor and hope for the best then tackle the oil level sensor below the oil pan, any ideas? PS:Oil was serviced beforehand and about the next day it started, also I did notice that the original pressure switch I replaced had two silver squares in it with a pin in the middle and a dot outside the housing, the new switch I got at AutoZone did not have the two squares in it (see photos for reference) it did had positive reviews including from someone the same year model as mine with no issues. I also reset the hood latch to make sure it wasn’t that.
cliffcoggin Posted September 7, 2024 Posted September 7, 2024 I am a little confused about whether you are discussing the oil pressure sensor or the oil level sensor, either of which could be defective. Is there an old-fashioned dipstick to first establish if the oil level is genuinely low?
Magnet Posted September 7, 2024 Posted September 7, 2024 Welcome Rigo, Judging by what you have already done, it just leaves the next stage of !Removed! in an oil pressure gauge and physically reading the running oil pressure following a 10 mile run to ensure the oil is up to operating temperature. Hold revs. steady at around 2000rpm and read the pressure. I don’t think - but certainly don’t know for definite - whether the running oil pressure reading can be seen digitally via. diagnostics. Worth researching that first. Let us know how you get on Rigo. Kind regards, Gareth. p.s. The ‘removed’ bit is to thread ( alternative word ) in ….
