Hi I have a 2006 Audi s3 8p and have a esp fault and steering wheel light on , this has only come on since changing the osr ABS sensor , it comes up with steering angle sensor which I have replaced , I have performed the rest to no avail , I keep seeing people posting about the rear diff earth strap but I cannot for the life of me find it or any sign of one being there also people were saying about the brake light switch which I have hunted high and low in the drivers footwell with the casing off , the bracket is there but no switch , please someone help with the location of the earth strap or can I just put a new one on in a chosen location
thanks
Dan (desperate Dan 馃槀)
Welcome Dan,
A school of thought to consider:-
Renewing the ABS sensor is fine. ( what brand did you use?)
The sensor is just that, it senses the signal from the wheel hub. I believe the sender (which the sensor receives it signal from) is integral with the hub, and it maybe this sender is at fault - and not the sensor.
If that is the case, then a replacement hub will be needed.
Febi hubs have been used to good effect.
Perhaps you could keep us updated on developments.
I replaced the sensor and it erased the ABS code on OBD but I still have ESP and steering light on which I can鈥檛 seem to turn it off I鈥檝e replaced loads of parts
Expand
Loads of parts tells us nothing. Have you replaced the hub as Magnet suggestd?
No I haven鈥檛 replaced the hub , I replaced the ABS sensor the steering angle sensor , the haldex filter and pump , have been searching for this illusive earth strap for the rear diff with no avail , so would you suggest replacing the hub ?
thanks
And that would be change the hub yeah ?
Thought that was the clear enough suggestion Dan, but if you want a positive answer to your yeah?  - it鈥檚 yes.
No need to be !Removed! , I came in here for some advice not sarcastic replies
Posted (edited)
When I replaced the rear hub/abs sensor the steering angle light went off only after doing a lock to lock steer.
And esp light went off after a short drive.
Edited by Rybrook
Expand
You were given the same advice several times but ignored it, and now you complain of sarcasm. I think you owe Magnet an apology.
Thanks Cliff, but there is no need for Dan to apologise.
I guess it鈥檚 what we can expect to top it off when we sit here being a rapid and free source of advice.
My turn to apologise to you Dan- I won鈥檛 be offering any further comments on your posts.
Expand
Thank you for a decent response
Expand
Well I鈥檓 sorry but being asked if I have replaced it doesn鈥檛 recommend replacing it so I just wanted to be sure , thank you for your time
Expand
I was asked if I had replaced it , that is a question ! Not advice
