Aransan Posted September 10, 2024 Posted September 10, 2024 Brake pad wear indicator does not reset after new pads and sensors
alpha omega Posted September 10, 2024 Posted September 10, 2024 did you do change them.....if the garage did them, then get them to reset it with their machine. 1
alpha omega Posted September 10, 2024 Posted September 10, 2024 (edited) 7 minutes ago, Aransan said: Changed by the garage take it straight back to them.their machine should turn it off.or the wiring could be corroded somewhere according to youtube Edited September 10, 2024 by alpha omega 1
Aransan Posted September 10, 2024 Author Posted September 10, 2024 The light should reset automatically after the replacement parts, the faulty wiring could be the problem. Thanks
Magnet Posted September 10, 2024 Posted September 10, 2024 Thanks Alan, but surely it’s not your responsibility to fix or diagnose. Did the car go to the garage with the warning light illuminated? Kind regards, Gareth. 1
dalswinton Posted September 11, 2024 Posted September 11, 2024 A new brake pad wear sensor cable should always be fitted when replacing the pads, if not, it could cause a bad connection where the end of the cable is connected to the brake pad, I have come across this problem in the past, worth a check. Brian. 2
