Help with reverse light... Gone somewhere..
Go to solution Solved by Mar4ix,
Hi folks, on my 3 door Audi A3 , 2008 ,聽 I've got that mystery with reverse light...
It's gone... It comes as warning once switch on ignition.聽
Light bulb 100% correct and working condition.聽
Connector off revers switch removed and joined wires in connector with bridge, when ignition on, no light comes up.
Searched in internet,couldn't found definitive answer, anyone have gone through this and may suggest where to find possible fault?聽
Many thanks in advance.聽
Regards
Regards
Hi its a bad earth on the rear of the light cluster, common problem.
Thanks. I will check that.. wouldn't whole cluster have that problem.? 馃
So, no power comes up. Any idea which wire is for reverse ?? Only 0.06 v on ignition on and in reverse and off reverse.聽
So just found that white wire, number 4, is power feed for reverse light.聽聽
Posted (edited)
Ok. 12 volts comes to switch on black with violet line colour wire, when I join the wires on switch, light not comes up. Second wire is blue. That means that blue wire is broken somewhere ... On the way to cluster... Will do test wire to the back.
Edited by Mar4ix
Sorry, that's number 5 , blue with red wire
  • Solution
Ok. Found problem. That wire before cluster was fixed many years ago by myself, used wrong wire, it corroded through...聽 So just get fix that wire and I'm sorted.... Thanks God nothing more serious 馃憦
On 9/12/2024 at 6:58 PM, cliffcoggin said:
Congratulations. Want a job?
馃ぃ
