Robbi Posted September 10 Share Posted September 10 Hi all I got an issue with an Audi q7 2014 plate the steering wobbles or shakes a little vibration when I go over 70 mph I have had tracking and balanced wheels still not right Braking is fine as I have had new discs and pads on Quote Link to comment Share on other sites More sharing options...
Steve Q Posted September 11 Share Posted September 11 Have you had a diagnostic check to see if any fault codes flag up. Worse case scenario is that it'll be an issue with the steering rack Quote Link to comment Share on other sites More sharing options...
Magnet Posted September 11 Share Posted September 11 Welcome Robi, and thanks for joining. Did the alignment people thoroughly check all aspects of the suspension and steering before making their adjustments, or did they simply stick it on the machine? When did this wobble occur? - have you had any new tyres on the car before it started? Any time tie up with having new discs and pads fitted? Are the tyre treads reasonably evenly matched on all four wheels, and are the brands matching - at least on the same axle? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Bigdave1230 Posted September 11 Share Posted September 11 Probably a slight buckle in one of the wheels. Swap the front wheels with the rear wheels and see if it still does it. Quote Link to comment Share on other sites More sharing options...
Magnet Posted September 12 Share Posted September 12 Thanks Dave, We are currently waiting for the OP to return to the forum to view any of the suggestions and questions asked, after asking for help. Quote Link to comment Share on other sites More sharing options...
