tryThis Posted September 15, 2024 Posted September 15, 2024 Hi, I have an A8 D4 2012 3.0TDI CDTA engine code with 184kW. The problem that i am facing is with the Oil Temperature Sensor. I get the P01BC - Engine Oil Temperature Sensor B Circuit High. I have changed the two sensors that are at the oil filter and the one that is in the oil pan. When i erase the error, i have no error and no check engine at the first start but at the second or third start i have the error and the check engine on. Can this behavior be caused of wire problems or maybe the sensors need some adaptations?
