CHRI1111 Posted 2 hours ago Share Posted 2 hours ago Hi, I have a 2006 Audi 1.6 FSI. It was low on power so I took it to the garage who advised the fuel pump has worn a grove in the cam lobe, and that the cam shaft and fuel pump will need to be replaced. There was no cam follower - should there be? It's not worth retaining the car based on the sum I have been quoted. Can I install a cam follower and replace the fuel pump rather then replace them both to cut down on cost? If not what about welding the groove in thd cam lobe? Any insight would be much appreciated. Chris. Quote Link to comment Share on other sites More sharing options...
